No joSlid píše:on nepsal o sub. on psal o předkách a zadkách
	Muzika E36
				dell
 - Klubové ID: 715
Co říkáte toto rádio?.
audio-katalog.czautorádiaNakamichi CD-700
AUTORÁDIA Nakamichi CD-700
Výrobce
Nakamichi
Produkt
AUTORÁDIA
CD-700
Objednávejte na tel. 272 740 116.M
O informace si pište e-mailem.
http://www.nakamichi.com
Cena: 65.999,- Kč
Preamplifier Section
Freqency response 15-30,000 Hz ± 1 dB (AUX to Pre Out)
Total Harmonic Distortion 0.001% (1 kHz)
AUX Input Level/Impedance 1 V/10 kohms
CDC Input Level/Impedance 1 V/10 kohms
Output level 5 V
Tone controls:
Bass: ± 12 dB @ 20 Hz
Midrange: ± 9 dB @ 1 kHz
Treble: ± 6 dB @ 20 kHz
FM Tuner Section
Frequency response 87.5-108.0 MHz in 50 kHz steps
Sensitivity 15 dBf (IHF)
Signal-to-Noise Ratio 60 dB (mono)
Stereo Separation 35 dB
Antenna Input 75 ohms (Unbalanced)
AM Tuner Section
Frequency response 531-1,602 kHz in 9 kHz steps
Sensitivity 32 dBµ
Signal-To-Noise Ratio 45 dB
CD Player Section
System Compact Disc digital audio
Error Correction CIRC principle
Sampling Frequency 44,1 kHz
D/A Converter Type 24-bit D/A converter with 8-times oversampling digital filter
Frequency Response 20 - 20,000 Hz ± 1 dB
Signal-to-Noise Ratio Better than 105 dB
Dynamic Range Better than 100 dB
Total Harmonic Distortion 0.003% (1 kHz)
General
Power Source 14.4 V DC, negative ground (10.8 - 15.6 V allowable)
Current Consumption 2,5 A
Installation Dimensions (WxHxD) 178 x 50 x 159.5 mm
Outer Dimensions (WxHxD) Main Unit: 178 x 46 x 177.8 mm, Power Supply Unit: 137 x 31.2 x 85 mm
Weight Main Unit: 1,6 kg, Power Supply Unit: 0,5 kg
Výrobce
Nakamichi
Produkt
AUTORÁDIA
CD-700
Cena: 65.999,- Kč
Output level 5 V
Tone controls:
FM Tuner Section
AM Tuner Section
Sensitivity 32 dBµ
CD Player Section
General
- Přílohy
- autoradia-nakamichi-cd-700.jpg (14.45 KiB) Zobrazeno 1089 x
 - Klubové ID: 482
dell píše:Co říkáte toto rádio?.
Výrobce
Nakamichi
Produkt
AUTORÁDIA
CD-700
Cena: 65.999,- Kč
Output level 5 V
Tone controls:
FM Tuner Section
AM Tuner Section
Sensitivity 32 dBµ
CD Player Section
General
sereš peníze?
podle parametrů vypadá dost good. ale nevím jeslti má smysl dát takovej ranec za radio.
				Ajwori
 - Klubové ID: 1016
na těhlech stránkách http://jehnert.de/de/ nabízejí tzv. Türpaneele / Doorboards vestavby do dveří do kterejch jdou umístit repráky to by moh bejt mazec stačí kliknoud na sound systém vybrat BMW a typ a pak jezdit myší po obrázku možnosti se zobrazí sami
						Jelikoz uz sem zoufalej ze standardniho CD radia a nemoznost mp3, muzete se mi pls kouknout na tenhle link kde jsou porovnany 4 radia a rict:
a)vase osobni zkusenosti ktery mate
b)ktery se vam zamlouva a proc
c)pripadne uplne jiny
Chci koupit radio ktery jakztakz zapadne do puvodniho interieru, tudiz cerny s cervernym/oranzovym podsvicenim.
Budu vdecny za rady, dikec.
http://www.hifishop.cz/Compare.asp?CMP= ... &DPG=41955
P.S:link se musi zkopirovat, blbne tu formatovani
oporucam kupit blaupunktKostik píše:Jelikoz uz sem zoufalej ze standardniho CD radia a nemoznost mp3, muzete se mi pls kouknout na tenhle link kde jsou porovnany 4 radia a rict:
kvalita super zvuk super a sprava sa ako original radio
- FreeTree
Z těchto 4 bych šel do Pio, i když jsem /////Alpine pozitiv, už jen pro barvu podsvícení, že si jí můžeš nastavit. Zvuk by měl být OK, tuner u Alpiny je slabší... U mý 9855 je těch barev mrtě. Kolik chceš do rádia investovat??? Za 8 litrů sezeneš /////Alpine hi-end rok starou, Clarion apod.!!!! Mrkni na http://www.autohificlub.cz
SLONY bych nechal někomu jinýmu
				Fikop
 - Klubové ID: 444
Cože??? Ty říkáš že nemusíš mít svázovanou celou audio sestavu? Proč je to u subu jedno?..nějaké divné nechip píše:Jestli myslíš na subu, tak tam je to fuk. Spíš ať znovu zkontroluje veškerou kabelážSlid píše:nemáš přehozené + -jurajko1 píše:ahojte.... dal som si do e36 nove radio Clarion DXZ 468RMP a nove repraky JBL GTO 527 dopredu a a komponentne JBL GTO 6507C dozadu. Vobec mi nehraju basy, aj ked nastavim maximum basov na vystupe z radia...... cim to moze byt ???....
				Fatal Design
 - Klubové ID: 1036
