můj slavnej retrofit soft close...
JaraX píše:sere se to, ale sere se celá šestka, tak to tam hezky zapadne. vzhledem k tomu že zvuk zavření dveří šestky připomíná konzervu, tak to je super upgrade.
ten JaraX je fakt jasnovidec
včera mi to začlo blbnout, po sotva dvou měsících
nedovře to úplně dveře viz první dvě videa, třetí je zámek na druhých dveřích
ten co blbne byl novej... je to v háji, nebo se s tím dá něco ještě dělat? o víkendu to rozeberu...
https://1drv.ms/f/s!AnpT35FgSPrKhclm3Ja-eiEiAe2lyQ
našel jsem k tomu dokumentaci
Locking Procedure
(When door is pushed into the lock starting position)
Door open, the automatic soft close function is in the standby position.
When the door is closed normally, first the locking pawl (lock) Hall sensor changes its status.
The electronics in the automatic soft close function drive start the door closing operation
after a delay of 200 ms. This prevents the automatic soft close function drive starting
before the lock bolt is located in the rotary striker.
The drive operates the rotary striker by way of the Bowden cable until the Hall sensor for
the rotary striker changes its status. The locking pawl is then engaged and secured in the
rotary striker. Control over the automatic soft close function drive is then withdrawn and
the automatic soft close function drive moves to the parked position.
When the door is opened using the outside door handle (bow handle) or inside door
handle, the system runs back to its original position. This is also known as the standby
position.
Note: Only when the rotary striker sensor has changed its status is the rotary
striker mechanically locked by the locking pawl. This is particularly
important, as only then is it guaranteed that the door is truly closed.
přijde mi, že mi to vůbec nedoběhne do stavu, aby druhý senzor změnil stav a vrátí se to do pohotovostního stavu...
v příloze celé povídání o tom, jak to funguje
