Diagnostika
- Joshuax
- Klubové ID: 2833
V DISu se da udelat test DPF, ten tam ma nejen vypsane hodnoty, pro max zpetny tlak na volnobeh i 2000 otacek, ktere si to pri testu nastavi a drzi samo, tak tam je jeden z kroku zapnuti pozadavku na regeneraci, pokud ji to auto samo delat z nejakeho duvodu nechce.
Edit: Tady jsou videt obrazky
http://forum.bmw5.co.uk/topic/89141-dpf ... nsor-test/
"And next you press the arrow and it will ask that if the permissible values were exceeded. Now in my test they weren't and I pressed "NO, which it will be the end of the test. But if yours were more than the permissible values or close to them, you press "YES and it will take you through couple of other screens which will tell you that the ECU will force a regeneration and that you need to drive the car for at least 30-40 mins at 60-80 kph on steady speed. After you come back leave the car for 30 mins to rest and repeat the test to compare the values. Hope this will be of help on saving the dreaded DPFs
Eddie"
Hlavne, po zapnuti pozadavku na provedeni regenerace, se objevi v aute error code A480 (alespon tak to je u E61) a ten nesmis smazat, jinak si ten pozadavek zase zrusis
Eddie"
