	jak a kde naprogramovat klíče?
1) Have your dealer hook up the shop computer (MODIC) to the car.
2) Go to the "Anti-Theft" activation section.
3) Activate the alarm, but uncheck the "DWA" option.
After this is done, your corner light should blink once when locked and twice when unlocked remotely. In addition, the clown nose will blink when car is locked just as if an alarm was present.
				Traviss
 - Klubové ID: 2495
Bohuzel nikoho s MODIC diagnostikou neznam, ale na STK jsem si to nechal pripojit na univerzalni a ta se pripojovala do mista v motorovém prostoru - konkretne, kdyz se koukas na motor tak vlevo je nadobka ostrikovacu, tlumic a za nim oddeleny prostor tak tam...
Jeste nevim, jestli se to nepripojuje nahodou na OBD zasuvku, ktera je na strane ridice, za krytem v leve dolni casti palubni desky..
Jinak pokud neco zjistis, alespon co za to chtelji v BMW, tak by me to taky zajimalo, blikani bych asi taky bral a treba i nastaveni automatickeho zamykani za jizdy by mohlo byt uzitecne, znam to z Peug.307 '07.
Ex e46 320d / Ex e39 540iAT / Ex e39 528i / Ex e39 540iAT #2 / Aktual Volvo S60 '01 2,3i T5@207kW LPG + SAAB 9-5 '99 2,3iA Turbo SportCombi 125kW + služební Yeti chrochták 4x4 + opět pošilhávám po BMW V8
 a vpravo Killca
