ALPINA B3 2.7 performance chip (204HP, 265Nm)
Filozof
Klubové ID: 1044
#1 Příspěvek od Filozof »
Našel jsem chip přímo od alpiny. Dá se to tedy přímo vyměnit s originálem a budu mít najednou o 13koní více ?
Kámoš o tom básní a já mu nedokážu odpovědět. Má E34 525i 1989.
Zajimala by mě zkušenost od někoho tady z klubu - kdo měl takto upravenej chip v autě.
Here we have ALPINA B3 2.7 performance chip for BMW M20 (6cylinder / 12valve) engine, e30 and e34 chassis.
The chip came of 1990 e30 Alpina B3 2.7 Kat (204HP, 265Nm). This is very rare item.
Performance gains depends from the engine condition and other mods (like sport exhaust system, cold air intake system, etc.).
8-10HP and 10-15Nm increase is expected on the regular 2.5 engine. Responsive and smooth acceleration, strong near the redline. The engine will rev faster and make very nice sound, aggressive sounding and very smooth 900 rpm idle. Rev limiter moved to higher but safe 6850 rpm zone.
Alpina B3 2.7 chip is also recommended for modified M20B25 engines or M20 327i / 328i conversions. Especialy if you have setup similar to original Alpina engine:
- 2.7 l displacement.
- Ported cylinderhead.
- 6 branch exhaust manifold
- High compression ratio pistons (~9.8:1)
- etc.
This setup will give you 204HP, 265Nm.
The chip was tested with 173 ECU and is in 100% working condition.
I can also provide instructions how to install the chip, if needed.
Idle: ~900rpm
Rev limit: ~6850rpm
e30 BMW 325i/is/ic/ix manufacture date 1987.09-1991.03
e34 BMW 525i manufacture date 1986.12-1990.09
Supported ECU's (Engine Control Unit):
BOSCH Motronic 0 261 200 172
BOSCH Motronic 0 261 200 173
BOSCH Motronic 0 261 200 380
Co na to říkáte
Helldiver
#2 Příspěvek od Helldiver »
Za pokus to stoji... Kazdopadne by som minimalne spravil aj konverziu na 2.7L, nech to ma rovnaky objem ako motor, na ktory je to urcene.
Huska
Klubové ID: 200
#3 Příspěvek od Huska »
Helldiver píše:Za pokus to stoji... Kazdopadne by som minimalne spravil aj konverziu na 2.7L, nech to ma rovnaky objem ako motor, na ktory je to urcene.
vždyť v tom popisu je uvedené že to jde i na 2,5l jen výkonbude vyšší jen o 8-10 PS .. já bych se toho nebál jen je otázkou ceny ... protože chipování atmosferického benzínu je k hovnu ... moje vlastní zkušenost :-(
:-) Born to be for BMW :-)
Filozof
Klubové ID: 1044
#4 Příspěvek od Filozof »
Huska píše:
kolem 50dolaru ....což jde ... podle mě když je to origo ALPINA CHIP
Spajky
Klubové ID: 1147
#5 Příspěvek od Spajky »
Filozof píše:
Huska píše:
no...bych si tu originalitu za tuhle cenu sakra prověřil :lol:
Filozof
Klubové ID: 1044
#6 Příspěvek od Filozof »
Koukal jsem se na netu a jsou tam chipy co s 2,5litrem vanosem dokáží 18-28koní nahoru ....to by mě teda zajimalo ... a posunují otáčkoměr o 400-600otáček nahoru.
Myslím si že kecají ...protože to by najednou mé auto dalo v poho 250km/h ne ? 525i
Určitě tady někdo byl kdo chipoval ....nejakej kvalitní chip ALPINE nebo DINAN...atd.
berkelay
Klubové ID: 1823
#7 Příspěvek od berkelay »
já bych tomu rozhodně nevěřil, to zvednutí výkonu u Apliny není čipem, ale těmi samotnými úpravami na motoru a změna RJ je jen následek úprav mechanických, myslím že samotný čip ti u benzínu nezvedne vůbec a spíš bych se bál, že se v tomto případě spíš něco "posere"
RuDoSh
Klubové ID: 5
#8 Příspěvek od RuDoSh »
Filozof píše:Určitě tady někdo byl kdo chipoval ....nejakej kvalitní chip ALPINE nebo DINAN...atd.
Ty chces cipovat radio? :lol:
Od dinanu se na jare chystam na "cipovani" prevodovky...
Filozof
Klubové ID: 1044
#9 Příspěvek od Filozof »
RuDoSh píše:
Ne radio ne ....a nechci čipovat ale jen mě to zajimalo. Pokud tady má někdo zkušenosti. Už mám dojem někdo něco dělal ne. Jinak chápu že bez více uprav na autě u atmosfery to nema smysl.
RuDoSh
Klubové ID: 5
#10 Příspěvek od RuDoSh »
i tak to asi risknu.... prvni ale po servisu zajedu na brzdu a po chipu znova, at vim jaky to melo smysl :-) .... na M70 dela chipy nejaky nemec a hodne osmickaru je chvali.... prevazne americani..... ale to bude az budu spokojeny s technickym stavem a opravim konecne ty kola a naraznik :-))
j3ykobim
Klubové ID: 1749
#11 Příspěvek od j3ykobim »
No nevim, já mám taky(prý) v jedné e34(m20) chip a posunutej otáčkoměr na 7000 a oprotí nechipovaný e34 (m20),my to přijde fakt svižnejší.....prý je tam o cca 10hp víc.........., ale zatim jsem to neověřoval...
Filozof
Klubové ID: 1044
#12 Příspěvek od Filozof »
Zajimalo by mě pokud při normálním provozu klesne spotřeba ....nebo je to mýtus.
RuDoSh
Klubové ID: 5
#13 Příspěvek od RuDoSh »
Filozof píše:Zajimalo by mě pokud při normálním provozu klesne spotřeba ....nebo je to mýtus.
no nevim.... u dyzlu mozna kdyz pojedes na spotrebu.... u atmosfery bych rekl, ze spis naopak....
