E46 N42B20 - nahodne zdechani
darklord
Klubové ID: 2970
#1 Příspěvek od darklord »
Riesim pre kamosa problem s motorom u E46 318i 2002, N42B20. Auto ide vcelku normalne, ovsem nahodne vynechava motor. Na neutral zakolisu alebo padnu otacky na nulu, v zatahu citit silne trhnutie ako keby sa motor vypol a nahodil.
Diagnostika pred testovacou jazdou (chyby co tam naskakali za posledny rok co som auto mal na PC):
Kód: Vybrat vše
E R R O R M E M O R Y
Date: 03.03.2015 11:01:02
ECU: ME9K_NG4
JobStatus: OKAY
Variant: ME9K_NG4
RESULT: 8 error in error memory !
277F CDKN - Crankshaft sensor
Error counter: 3
Logistic counter: 53
1. Umweltsatz
Mileage 522610 km
Engine speed (nmot) 2720.00 /min
Engine temperature (tmot) 114.75 degrees C
Ambient temperature (tumg) -48.00 Grd C
Supply voltage (ub) 19.03 V
2. Umweltsatz
Mileage 185860 km
Engine temperature (tmot) 116.25 degrees C
Supply voltage (ub) 16.58 V
3. Umweltsatz
Mileage 175710 km
Engine speed (nmot) 2840.00 /min
Engine temperature (tmot) -39.00 degrees C
Supply voltage (ub) 16.67 V
Leitungsunterbrechung Drehzahlsignal
Test conditions fulfilled
Error not present now, but already stored
Error would not cause a warning lamp to light up
Error code: 08 27 7F 24 21 03 35 CC 25 44 D9 00 CA 48 9A 44
DB 00 B0 44 A3 47 0C 00
2782 CDKPH2 - Camshaft sensor outlet
Error counter: 3
Logistic counter: 102
1. Umweltsatz
Mileage 361340 km
2. Umweltsatz
Mileage 185670 km
Engine temperature (tmot) 133.50 degrees C
Supply voltage (ub) 17.33 V
3. Umweltsatz
Mileage 218880 km
Engine temperature (tmot) -38.25 degrees C
Supply voltage (ub) 17.05 V
Lage der Phasenflanken oder Einbaulage ausserhalb Toleranz
Error code: 08 27 82 24 21 03 66 8D 26 44 D9 00 CA 48 87 44
F2 00 B8 55 80 47 0D 00
2731 CDKENWS - Camshaft control inlet - VANOS
Error counter: 0
Logistic counter: 17
1. Umweltsatz
Mileage 79740 km
Engine speed (nmot) 2800.00 /min
Engine temperature (tmot) 28.50 degrees C
rel. air filling (rl) 33.75 %
wnwi1_u 180.00 Grad KW
2. Umweltsatz
Mileage 59060 km
Engine temperature (tmot) 30.00 degrees C
rel. air filling (rl) 21.75 %
wnwi1_u 182.00 Grad KW
3. Umweltsatz
Mileage 43830 km
rel. air filling (rl) 48.00 %
wnwi1_u 197.00 Grad KW
Anschlagadaption ausserhalb gueltigen Bereich
Error code: 08 27 31 22 21 00 11 1F 26 46 66 2D B4 17 12 46
68 1D B6 11 1F 47 0C 40
27BB CDKANWS - Camshaft control outlet-VANOS
Error counter: 0
Logistic counter: 21
1. Umweltsatz
Mileage 84860 km
Supply voltage (ub) 16.96 V
2. Umweltsatz
Mileage 60200 km
rel. air filling (rl) 22.50 %
Supply voltage (ub) 17.14 V
3. Umweltsatz
Mileage 47410 km
rel. air filling (rl) 0.00 %
Anschlagadaption außerhalb gültigem Bereich
Error code: 08 27 BB 22 21 00 15 21 26 46 66 2D B4 17 84 46
68 1E B6 12 85 47 0D 00
2799 CDKDVEUB - Abort DV-adaption because of enviroment
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 399760 km
Supply voltage (ub) 20.06 V
Intake air temperature (tans) -48.00 degrees C
norm. driver pedal angle (wped) 38.83 %
2. Umweltsatz
Mileage 227840 km
norm. driver pedal angle (wped) 40.40 %
3. Umweltsatz
Mileage 227840 km
Supply voltage (ub) 1.32 V
norm. driver pedal angle (wped) 35.30 %
Lernverbot Status Prüfbedingung = 27
Error code: 08 27 99 22 25 00 00 9C 28 46 D5 00 63 59 00 46
D5 00 67 59 00 47 0E 00
2727 CDKLASH2 - Lambda sensor ageing after cat bank2
Error counter: 1
Logistic counter: 89
1. Umweltsatz
Mileage 8050 km
Cat temp. out of the model bank2(tkatm2) 1090.00 Grd C
Inside resistor LS before cat bank2 (rinh2) 4224.00 Ohm
Sensor voltage before cat bank2 (ushk2) 0.31 V
2. Umweltsatz
Mileage 231080 km
Cat temp. out of the model bank2(tkatm2) 1170.00 Grd C
Inside resistor LS before cat bank2 (rinh2) 4864.00 Ohm
Sensor voltage before cat bank2 (ushk2) 0.30 V
3. Umweltsatz
Mileage 680 km
Cat temp. out of the model bank2(tkatm2) 1185.00 Grd C
Inside resistor LS before cat bank2 (rinh2) 3840.00 Ohm
Sensor voltage before cat bank2 (ushk2) 0.23 V
Schubspannungsschwelle nicht erreicht
Error present now and already stored
Error code: 08 27 27 64 01 01 59 03 25 46 E4 42 62 5A 44 46
F4 4C 5F 00 44 46 F7 3C
2783 CDKLM - Hot film air mass meter
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 36090 km
Intake air temperature (tans) -46.50 degrees C
Angel DK or DK at stop (wdkba) 14.51 % DK
ADC HFM (adhfm) 1.57 V
2. Umweltsatz
Mileage 31260 km
Angel DK or DK at stop (wdkba) 18.04 % DK
3. Umweltsatz
Mileage 44120 km
ADC HFM (adhfm) 1.55 V
Signal oberhalb Schwelle oder Kurzschluss nach Plus
Error not occurred yet
Error code: 08 27 83 01 01 00 00 0E 19 47 02 25 50 0C 36 47
02 2E 50 11 3C 47 02 2E
2781 CDKPH - Camshaft sensor inlet
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 8050 km
Engine temperature (tmot) -45.00 degrees C
Ambient temperature (tumg) -18.75 Grd C
Supply voltage (ub) 6.69 V
2. Umweltsatz
Mileage 175210 km
Engine temperature (tmot) -39.75 degrees C
Ambient temperature (tumg) -20.25 Grd C
Supply voltage (ub) 7.44 V
3. Umweltsatz
Mileage 188050 km
Ambient temperature (tumg) -24.75 Grd C
Supply voltage (ub) 6.78 V
Error code: 08 27 81 04 01 00 00 03 25 47 04 27 47 44 71 47
0B 25 4F 49 75 47 0D 1F
Chyby som zmazal a dali sme testovaci okruh, v stupani do kopca auto vynechalo, hned sme parkli, a po par minutach na volnobehu zakolisalo a zdochlo.
Chyba co naskocila:
Kód: Vybrat vše
Date: 03.03.2015 11:17:12
ECU: ME9K_NG4
JobStatus: OKAY
Variant: ME9K_NG4
RESULT: 1 error in error memory !
Error counter: 0
Logistic counter: 0
1. Umweltsatz
Mileage 2960 km
Engine temperature (tmot) -36.75 degrees C
rel. air filling (rl) 16.50 %
Supply voltage (ub) 18.37 V
2. Umweltsatz
Mileage 47910 km
Engine speed (nmot) 10200.00 /min
Engine temperature (tmot) 143.25 degrees C
rel. air filling (rl) 191.25 %
Supply voltage (ub) 24.02 V
Error present now, but not yet stored (debouncing phase)
Error code: 01 27 BB 42 05 00 00 01 28 47 0F 16 C3 12 B7 FF
FF FF FF FF FF FF FF FF
Moja otazka znie, da sa spolahlivo urcit ktore cidlo otacok je na vine, az nekupujeme vsetky tri? Predpokladam ze chyby na vackach mozu naskakovat nie z dovodu samotnej zavady na vackovych cidlach, ale moze to sposobovat spatne cidlo na klukovke, to ovsem po zakolisani pri testovacej jazde nenaskocilo...
Dalej mam jeden obrazok z INPY, znepokojuju ma tie dve vyskocene adaptacie, je to vzhladom na tuto zavadu alebo ide o normalny stav?
INPA analog values 4
Bez názvu.png (36.64 KiB) Zobrazeno 1600 x
Miguel
Klubové ID: 1507
#2 Příspěvek od Miguel »
Tak logicky vyměníš čidlo které bude hlásit chybu, tudíž to na výfukové vačce.
darklord
Klubové ID: 2970
#3 Příspěvek od darklord »
Ta druha diagnostika ale nehlasi chybu cidla :) A v prvej su hodene vsecky tri.
vita11 Moderátor
Klubové ID: 3376
#4 Příspěvek od vita11 Moderátor »
Ta druhá hlásí ovládací ventil Vanosu výfukové vačky
