Tak mi asi pomalu ale jistě odešla nějaké flash paměť u modulu ... píše to error na registrech ...
nevíte někdo co s tím popř kdo by to uměl opravit??? Předem moc díky za tip ...
E R R O R M E M O R Y ---------------------------------------
Date: 26.10.2016 22:31:28 ECU: CCCG60 JobStatus: OKAY Variant: CCCG60-------------------------------------------------------------
RESULT: 3 error in error memory !-------------------------------------------------------------
E18F central Registry does not match with debit configuration (Error_Registry_New).
Error counter: 15 Logistic counter: 40
1. Umweltsatz Mileage 198144 km VDO-Error ee7ce18f Hex Diagnosis Adress 3f Hex dummy2 00000000 Hex dummy3 00 Hex
2. Umweltsatz Mileage 198144 km VDO-Error ee7ce18f Hex Diagnosis Adress 3f Hex dummy2 00000000 Hex dummy3 00 Hex
No matching error symptom Test conditions fulfilled Error not occurred yet Error would not cause a warning lamp to light up
Error code: E1 8F 00 0F 28 60 C0 EE 7C E1 8F 3F 00 00 00 00 00 60 C0 EE 7C E1 8F 3F 00 00 00 00 00-------------------------------------------------------------
E18C Device didn't accept or confirm monitoring message. (Error_Monitoring).
1. Umweltsatz Mileage 198144 km VDO-Error ee7ce18c Hex Diagnosis Adress ff Hex dummy2 00000000 Hex dummy3 00 Hex
2. Umweltsatz Mileage 198144 km VDO-Error ee7ce18c Hex Diagnosis Adress ff Hex dummy2 00000000 Hex dummy3 00 Hex
Error code: E1 8C 00 0F 28 60 C0 EE 7C E1 8C FF 00 00 00 00 00 60 C0 EE 7C E1 8C FF 00 00 00 00 00-------------------------------------------------------------
E18E Although Shutdown(Execute) was sent light did not switch off (Error_Light_Not_Off).
Error counter: 1 Logistic counter: 40
Mileage 198144 km VDO-Error ee7ce18e Hex dummy1 0000 Hex dummy2 00000000 Hex
Error code: E1 8E 00 01 28 60 C0 EE 7C E1 8E 00 00 00 00 00 00 =============================================================
CCC modul oprava BMW e63
ManyP
- Klubové ID: 102
BMWcesky
- Klubové ID: 3672
Re: CCC modul oprava BMW e63
Já to opravuji. 773974618
hansm5
kolik to stojiBMWcesky píše:Já to opravuji. 773974618
