Servisni interval - reset IDrive?
majkouch
Klubové ID: 2768
#1 Příspěvek od majkouch »
krom e60 a e90 fora (podle návodu tam mi to nefunguje) sem nikde nenašel návod jak resetovat servisní interval - např. po výměně brzdovky, aby se termin výměny o dva roky posunul...
poradí někdo nějakou další možnost?
podle návodu z e90 to jde až po bod kdy se má objevit nápis "RESET"
ten se jaksi neobjeví :-(
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
majkouch
Klubové ID: 2768
#2 Příspěvek od majkouch »
tak nevim jestli ten dotaz smazat nebo to tu nechat, ale našel sem to tady:
https://www.youtube.com/watch?v=4pKz4-9r7ik
gsicbr
#3 Příspěvek od gsicbr »
dneska jsem nastavoval interval na DPF přes nulování počítadla km a za chvilku hotovo. Tak nevím kde děláš chybu.
