ZDAR. VRŽE SERVO JAK ŠÁHNU NA VOLANT. MŮŽE TO BÝT MÁLO OLEJE? KOUKAL SEM NA TO VECER ALE BYLO HOUBY VIDET. NAVÍC TEN OLEJ MĚL NEHEZKOU BARVU. TAK BYCH HO VYMENIL CELEJ.
JAKEJ TAM MÁ BEJT?
A JAK HO VYMENIT? JE TAM NEJAKEJ VYPOUSTECI VENTIL, NEBO MUSIM ODPOJIT HADICKU OD NADOBKY, NECHYT VYTECT A NALEJT NOVEJ?
Vrže SERVO v E36 318
_peper
- Klubové ID: 1129
tapin
