Takže takhle vypada ten origo zesík a piny jsou rozepsane o pár řádku níž. Doufám vám to bude stačit.
http://imgupload.cz/muj.php?obrazek=CuneAAOpbB.JPG
A18 Amplifier
Plug connector overview
Number X-pin, colour Description
X605 12-pin, black Plug connector A Amplifier
X606 26-pin, black Plug connector B Amplifier
Pin assignments at plug connector X605
Pin Type Description / Signal type Connection /
Measuring notes
1 E Terminal 30 Plug connector I
2 E Radio ON/antenna signal Antenna amplifier
3 M Amplifier ground Ground connector
4   Not used
5 A Positive activation, rear right woofer Right rear speaker
6 A Negative activation, rear right woofer Right rear speaker
7 A Positive activation, front left woofer Left front speaker
8 A Negative activation, front left woofer Left front speaker
9 A Positive activation, front right woofer Right front speaker
10 A Negative activation, front right woofer Right front speaker
11 A Positive activation, rear left woofer Left rear speaker
12 A Negative activation, rear left woofer Left rear speaker
Pin assignments at plug connector X606
Measuring notes
1 E Negative activation, rear right loudspeaker Radio
2 E Positive activation, rear right loudspeaker Radio
3 E Positive activation, rear left loudspeaker Radio
4 E Negative activation, rear left loudspeaker Radio
5   Not used
6   Not used
7   Not used
8 A Positive activation, front right medium-range speaker Right front speaker
9 A Negative activation, front right medium-range speaker Right front speaker
10 A Positive activation, rear left tweeter Left rear speaker
11 A Negative activation, rear left tweeter Left rear speaker
12 A Positive activation, rear right tweeter Right rear speaker
13 A Negative activation, rear right tweeter Right rear speaker
14 E Negative activation, front right loudspeaker Radio
15 E Positive activation, front right loudspeaker Radio
16 E Positive activation, front left loudspeaker Radio
17 E Negative activation, front left loudspeaker Radio
18   Not used
19   Not used
20   Not used
21 A Positive activation, front left tweeter Left front speaker
22 A Negative activation, front left tweeter Left front speaker
23 A Positive activation, front right tweeter Right front speaker
24 A Negative activation, front right tweeter Right front speaker
25 A Positive activation, front left mid-range speaker Left front speaker
26 A Negative activation, front left mid-range speaker Left front speaker
A18 Amplifier
X18771 15-pin, black Plug connector A Amplifier
X18772 18-pin, black Plug connector B Amplifier
X18773 26-pin, black Plug connector C Amplifier
Pin assignments at plug connector X18771
Measuring notes
1 A Positive signal, subwoofer speaker 1 Subwoofer speaker
2 A Positive signal, subwoofer speaker 2 Subwoofer speaker
3 A Positive activation, rear left woofer Left rear speaker
4 A Antenna signal Connector, antenna amplifier
5 E Negative activation, rear right woofer Right rear speaker
6 E Negative signal, subwoofer speaker 4 Subwoofer speaker
7 E Negative signal, subwoofer speaker 3 Subwoofer speaker
8 E Terminal 30 Fuse F69
9 E Negative signal, subwoofer speaker 1 Subwoofer speaker
10 E Negative signal, subwoofer speaker 2 Subwoofer speaker
11 E Negative activation, rear left woofer Left rear speaker
12 A Positive activation, rear right woofer Right rear speaker
13 A Positive signal, subwoofer speaker 4 Subwoofer speaker
14 A Positive signal, subwoofer speaker 3 Subwoofer speaker
15 M Ground Ground point
Pin assignments at plug connector X18772
Measuring notes
1   Not used
2 E Negative signal, low frequency Transceiver/charging electronics
3   Not used
4   Not used
5 E/A I-bus signal line I-bus connector
6   Not used
7   Not used
8 E Negative activation, front right loudspeaker Radio
9 E Negative activation, front left loudspeaker Radio
10   Not used
11 A Positive signal, low frequency Transceiver/charging electronics
12   Not used
13 E Telephone mute signal Transceiver/charging electronics
14   Not used
15 E Signal line, night lights Eject box
16   Not used
17   Positive activation, front right loudspeaker Radio
18 E Positive activation, front left loudspeaker Radio
Pin assignments at plug connector X18773
Measuring notes
1 A Positive activation, front left woofer Left front speaker
2 A Negative activation, front left woofer Left front speaker
3   Not used
4 A Negative activation, front right medium-range speaker Right front speaker
6   Not used
7   Not used
8   Not used
9 A Positive activation, front right medium-range speaker Right front speaker
10 A Negative activation, front left mid-range speaker Left front speaker
11 A Positive activation, rear right tweeter Right rear speaker
12 A Positive activation, front right tweeter Right front speaker
13 A Positive activation, front right woofer Right front speaker
14 A Positive activation, front left tweeter Left front speaker
15 A Negative activation, front left tweeter Left front speaker
16 A Negative activation, rear left tweeter Left rear speaker
17   Not used
18   Not used
19 A Positive activation, rear left tweeter Left rear speaker
20   Not used
21   Not used
22   Not used
23   Not used
24 A Negative activation, rear right tweeter Right rear speaker
25 A Negative activation, front right tweeter Right front speaker
26 A Negative activation, front right woofer Right front speaker
