X3 F25 xdrive28i (2010-17) - diagnostika (chybové hlášky)
Androy
#1 Příspěvek od Androy »
Ahoj,
vi nekdo co presne znamenaji tyto hlasky z diagnostiky ? hledal jsem na netu a moc z toho moudry nejsem...
DME (Engine-Digital Motor Electronics) —— ( 3 )
1.1. CD9203 LIN message; radiator shutter: missing - Permanent
1.2. 120308 Charge-air pressure control, plausibility: pressure too low - Intermittent
1.3. 108F01 Intake plenum: suspicion of leakage between exhaust turbocharger and intake valves - Intermittent
2. ABS-DSC (ABS-Dynamic Stability Control) —— ( 2 )
2.1. 480A90 Dynamic Stability Control (DSC): roller brake tester mode active - Intermittent
2.2. 4809AB Dynamic Stability Control (DSC): undervoltage in vehicle - Intermittent
Diky moc za pomoc.
