Cidla vseho druhu
Hanz
- Klubové ID: 6
LOPOLO
- Čestný člen
- Klubové ID: 1
darmon: jeste k tem nesmyslnejm udajum o spotrebe ... mozna zkusim tuhle kalibraci i kdyz si nemyslim ze to pomuze. Porad mi to nejde.
Note on test #20:
The factor is used to correct the OBC Avg Fuel Consumption figure to reality. If your OBC is off a bit: fill UP totally, run tank down and refill; then calculate your Actual MPG. Now enter test 20 to get the old Correction Factor.
NEW CF= OLD CF *(OBC MPG/Actual MPG)
Enter the NEW CF using the numeric keys and hit SET/RES to store. PLEASE record your OLD CF so that IF you screw up you can always go back to what it was.
je to z tyhle stranky
Note on test #20:
