Dálkové otevírání vrat
Sweden
- Klubové ID: 2669
hurvajs77
- Klubové ID: 2855
Snad Ti to pomůže...
Fixed code hand-held transmitter
1. Switch on the ignition
2. When using for the first time: press both outer keys 1 for approx. 20 seconds, maintaining pressure until the indicator lamp 2 starts to flash. The three memory keys 1 are cleared
3. Hold the original hand-held transmitter at a distance of approx. 2 in (5 cm) to 8 in (20 cm) from the memory keys 1. The required distance between the hand-held transmitter and memory keys 1 depends on the relevant system of the original hand-held transmitter used.
4. Simultaneously press the transmit key on the original hand-held transmitter and the desired memory key 1 of the integrated universal remote control. First, the indicator lamp 2 flashes slowly. Release both keys 2 as soon as the indicator lamp flashes rapidly. If the indicator lamp 2 does not flash quickly after approx. 15 seconds, choose another distance
5. To program other original hand-held transmitters, repeat steps 3 and 4.
The corresponding memory key 1 is now programmed with the signal of the original hand-held transmitter.
The device can be operated as of ignition on. If the device can not be operated after repeated programming, check whether the original hand-held transmitter uses an alternating-code system. To do so, either read the instructions of the original hand-held transmitter or press and hold down the programmed memory key 1 of the integrated universal remote control. If the indicator lamp 2 on the integrated universal remote control flashes quickly for a brief period and then remains lit up for approx. two seconds, this indicates that the original hand-held transmitter is equipped with an alternating code. In the case of an alternating-code system, program the memory keys 1 as described at the section on alternating-code transmitters.
Alternating-code transmitters
Consult the operating instructions of the unit you wish to set when programming the integrated universal remote control. Find out about the possibility for synchronization.
When programming hand-held transmitters that employ an alternating code, please observe the following supplementary instructions: Programming will be easier with the aid of a second person.
1. Park your vehicle within the range of the remote-controlled device
2. Program the integrated universal remote control as described at the section on fixed code hand-held transmitters.
3. Localize the key on the receiver of the device you want to set up, e.g. on the upper section of the motor
4. Press the key on the receiver of the device you want to set up. After step 4, approx. 30 seconds remain for step 5
5. Press the programmed memory key 1 on the integrated universal remote control three times.
The corresponding memory key 1 is now programmed with the signal of the original hand-held transmitter. If you have any additional questions,
please contact your BMW center.
Clearing memory keys
Individual memory keys 1 can not be cleared. However, you clear all three memory keys 1 together as follows:
Press both outer keys 1 of the integrated universal remote control for approx. 20 seconds, maintaining pressure until the indicator lamp 2 starts to flash.
E65 730d
E61 530xd - stolen
E32 730i V8 - ex
E32 735i - ex
E32 730i - ex
E65 730d
E61 530xd - stolen
E32 730i V8 - ex
E32 735i - ex
E32 730i - ex
Sweden
- Klubové ID: 2669
Vlasta
- Klubové ID: 148
hurvajs77
- Klubové ID: 2855
no to jsi nepsal... :-D Ani mě to nikdy nešlo a teď nemám dálkové otevírání garaáže, takže to neřešímSweden píše:Diky Hurvajs,tenhle postup mam v orig.manualu v nemcine,nejak se mi to porad nedari sladit.
E65 730d
E61 530xd - stolen
E32 730i V8 - ex
E32 735i - ex
E32 730i - ex
E65 730d
E61 530xd - stolen
E32 730i V8 - ex
E32 735i - ex
E32 730i - ex
Sweden
- Klubové ID: 2669
Nepsal jsem to protoze Nj davam jenom tam hrube,v Aj celkem dobry,vse delam spravne,smazu pameti,drzim otvirani a zaroven drzim jeden z cudlu,dioda blika pomalu tak jak ma ale pak po 15 vterinach se nerozblika rychla tak jak by po ulozeni mela.
Kdyby se ti podarilo sehnat zbytek toho manualu v Aj tak budu vdecny,v mojem manualu je posledni kapitola ktera se venuje prave zmene frekvenci a.vecem kolem toho,jak pise Vlasta,problem bude asi tam.
Nijak extra to nepotrebuju,ale kdyz to tam mam tak bych to rad sprovoznil,takovahle ficura nemusi byt spatna kdyz clovek zapomene nebo strati klice,otvirac na vrata apod.,takova posledni zachrana,jenom to dat do.chodu no
