Bmw E60 problem s baterkou
borsalino696
DOBRY DEN PROSIM O RADU MAM BMW 530D R.V 2006 PRI UJETI CCA 100KM PO DALNICI SE MI ROZSVITILA KONTROLKA PREVODOVKA TAK JSEM ZASTAVIL BOHUZEL AUTO UZ JSEM NENASTARTOVAL UKAZALO SE ZE BATERKA JE VYBITA TAK JSEM MUSEL SEHNAT NOVOU 100AH DAL JSEM JI TAM A AUTO JEDE A V TEN DEN JSEM NAJEL JESTE 500KM A BEZ PROBLEMU PROSIM O RADU CO BY MOHLO BYT POKAZENE.DIKY
beny-maser
clay
baterka nebo dobijeni, moc moznosti neni... nebo ten zapnuty CAPS LOCK by mohl hodne zratborsalino696 píše:DOBRY DEN PROSIM O RADU MAM BMW 530D R.V 2006 PRI UJETI CCA 100KM PO DALNICI SE MI ROZSVITILA KONTROLKA PREVODOVKA TAK JSEM ZASTAVIL BOHUZEL AUTO UZ JSEM NENASTARTOVAL UKAZALO SE ZE BATERKA JE VYBITA TAK JSEM MUSEL SEHNAT NOVOU 100AH DAL JSEM JI TAM A AUTO JEDE A V TEN DEN JSEM NAJEL JESTE 500KM A BEZ PROBLEMU PROSIM O RADU CO BY MOHLO BYT POKAZENE.DIKY
beny-maser
PPetr
janwert
