Caute,
INPA mi vyhodila tuto chybu:
78 KLIMA OKAY 1Error stored
9C76 62
ECU: IHKA65
Variant: IHKA65
9C76 Auxiliar water pump
Error counter:9
Logistic counter:40
Outside temperature 10.50 degrees C
cooling fluid temperature 56.00 degrees C
Battery Voltage 11.70 Volt
relative time 30920363.00s
Signal or value below threshold
Test conditions fulfilled
Error present now and already stored
Error would not cause a warning lamp to light up
Error code: 9C 76 62 00 09 28 99 87 65 68 75 01 D7 CE AB
Neviete co to znamena?Klima mi normalne ide,chladi,ja osobne nevidim ziadny problem,len ma znervoznuje tato chyba ulozena.
Dik za pomoc
e65 - klima hlásí chybu Auxiliar water pump
- Klubové ID: 482
