E46 ///M3 a CSL
GeorgosAc Čestný člen
Klubové ID: 117
#1 Příspěvek od GeorgosAc Čestný člen »
E46 ///M3
The final production version was then unveiled the following March at the 2000 Geneva Motor Show
BL91: European-spec coupe (LHD), 09/00-05/06
BL92: European-spec coupe (RHD), 02/01-05/06
BL93: North American-spec coupe (LHD), 02/01-05/06
BR91: European-spec convertible (LHD), 03/01-08/06
BR92: European-spec convertible (RHD), 04/01-08/06
BR93: North American-spec convertible (LHD), 03/01-08/06
BL95: European-spec CSL coupe (LHD): 05/03-12/03
BL96: European-spec CSL coupe (RHD): 06/03-12/03
coupe
convertible
motor S54 3,2LThe S54 engine in the E46 M3 is rated at 343 hp (DIN) or 333 hp (SAE) at 7,900 rpm and 262 lb/ft of torque at 4,900 rpm.
SMG II. introduced (9/01)a fofrklacek
The E46 M3 utilizes a Getrag Type D six-speed manual gearbox with the following ratios: 4.23 (1), 2.53 (2), 1.67 (3), 1.23 (4), 1.00 (5), 0.83 (6). This is mated to a 3.62:1 final drive with M Variable Differential Lock.
špígly pro E46 ///M
detail výdechu
zadní svetla od (3/03)
kola pro E46 ///M
18palcu
19palcu
detail vozu
interier vozu
///M3 GTR - speciální verze vozu - 250,000 Euro
Titanium Silver metallic (354).
carbon
E46 ///M3 CSL
kola pro CSL
motor CSLThe CSL-spec engine is rated at 360 hp (DIN) at 7,900 rpm and 273 lb-ft of torque at 4,300 rpm.
interiér CSL
Exterior Colors:
Alpine White III (300), Imola Red (405), Jet Black (668), Laguna Seca Blue*** (448), Titanium Silver metallic (354), Steel Grey metallic* (400), Silver Grey metallic** (A08), Carbon Black metallic (416), Oxford Green metallic*** (430), Phoenix Yellow metallic**** (445), Topaz Blue metallic* (364), Mystic Blue metallic** (A07), Interlagos Blue metallic***** (A30)
*thru 2/03
**from 3/03
***thru 8/04
****thru 2/05
*****ZCP/M3 CS only
Interior Colors:
Anthracite M Alcantara/Black Nappa leather (coupe only, special order for U.S. until 9/05), Anthracite Impulse cloth/Black Nappa leather (thru 08/05, coupe only), Black Nappa leather, Grey Nappa leather, Imola Red Nappa leather, Cinnamon Nappa leather, Laguna Seca Blue Nappa leather (special order for U.S.) , Kiwi Nappa leather (special order for U.S.) NOTE: Extended Nappa leather interior was also offered in some markets
Interior Trims:
High-Gloss Black (standard thru 08/01), Titan Shadow (standard from 09/01), Aluminum, Milled-Effect Aluminum (ZCP/CS only), Eucalyptus Malt Wood (only by special order in USA)
Klubové ID: 117
#2 Příspěvek od GeorgosAc Čestný člen »
a ještě řez motorm
pavproch
Re: E46 ///M3 a CSL
#3 Příspěvek od pavproch »
