Mam na predaj komplet sadu - novu FISCUBE pre auta s jednotkami CCC professional, (nie pre MASK, nie pre CIC atd...)
je to integracie televizie DVB-T a taktiez moznost pripojenia USB pre prehravanie MP3 alebo formatu DivX.\ (je tam aj funkcia nahravania z tv na usb kluc)
Cena za cely kit je 300eur + postovne. Je k tomu instalacny manual a treba nasledne nakodovat vo vozidle funkciu TV (SA601) v CCC.
(nie je vhodne pre vozidla s predoslou instalaciou TV modulu)
Tu je nejake video od oficialneho predajcu (ktory uz mimochodom tento "FISCUBE" nepredava.
https://www.youtube.com/watch?v=g9WCCFnpiZU
Prosim vas nepytajte sa ma ci vam to nainstalujem do auta - odpoved zne "nie". (Niesom autoservis, ani instalacne stredisko. Instalacia vo vasej vlastnej rezii.)
Sada pozostava s jednotky, 2x antena ktore je treba instalovat na nejake vhodne miesta, k tomu kabliky, optokabliky apd.
Pripajam este popis v anglictine:
FISCUBE - the perfect mix
- One multimedia device which leaves nothing to be desired
DVB-T digital TV directly on the original screen of the vehicle
Record TV through USB connection
Playing MP3 as well as Video files through USB connection
- Full integration into the infotainment system of the vehicle
- OEM-menu driven operation by using:
iDrive operation panel
Multifunctional steering wheel (if available)
- No installation of additional screens, speakers or operation panels necessary
- Suitable for the following vehicles with Infotainment System CCC Navigation Professional:
1er - E81, E82, E87, E88
3er - E90, E91, E92, E93
5er - E60, E61
6er - E63, E64
X5 - E70
X6 - E71
- NOTE CCC: Vehicles with a brown iDrive screen a software update is required before installation. The system is only working for vehicles with a silver/ gray screen. Please get in contact with a local BMW dealer for upgrading.
Features - Interface
- E13 certification - 10R-03-12423
- TV - Tuner - Emulation
- Standby current < 0,01 mA
- Input aerials 2x F-connector
- USB connection
- Dimension (LxBxH): 11,4cm x 9,2cm x 3,1cm
USB connection
- USB connection for an external HDD* or memory stick
- USB-source format using FAT32
- Playing MP3 as well as Video files
- Display of information about track as well as interpret on the MMI screen
- Last-Position-Memory
For music files - the last listen track will start again from the beginning
For video files - will start again directly where the video has been stopped playing
- Supported audio files: *.mp3, *.wav
- Supported video files: *.mpg; *.dat; *.vob; *.avi (MPEG4 ASP, XviD, DivX4.0/5.0/6.0)
- Recorded file format: *.mpg
DVB-T
- Integrated automotive receiver
- Record TV through USB connection
- Replay of records at a later date
- Frequency: 145.1MHz ~ 862 MHz
- Channel bandwidth: 6/7/8 MHz
- Video/Audio decoding: MPEG II
No HDTV
No MPEG4
No CAM-slot for Pay-TV smart cards (e.g. needed in the Netherlands)
- Resolution: 720x576 (PAL) / 720x480 (NTSC)
Scope of delivery
- FISCUBE interface
- Specific wiring
- 2 active aerials
Note
- *Only for HDD's with a current consumption < 500mA - In case of more than 500mA an external power source will be needed
Fiscube pre CCC Professional - DVB-T + USB Mp3/DivX
airbone
- Klubové ID: 1836
airbone
- Klubové ID: 1836
