E39 2002 525I Tour trosku se trepe
rzich
Klubové ID: 2009
#1 Příspěvek od rzich »
No tak jsem si koupil neco malinko mladsiho bohuzel....asi ten M54b25(170000km) nebude buhvico
Auto jsem projel pred koupi, zdalo se byt ok, mozna melo trosku nizsi otacky na volnobeh nez moje stara e39 98sma asi kolem 720/min.Jsem si rikal jiny motor tak to tam muze byt.Od dealera asi 50 km asi celkem ok ale ridil to kamos,nerikal nic a ja jsem jel svym starym.
No pak jsem to doma napichl(skoda mel jsem to udelat pred koupi)
PA soft prvni den:
DME -> EF/B2 - Misfire, cylinder 2, misfiring during warm up, worsening emissions (Misfire CARB_B1)
F1/B2 - Misfire, cylinder 4, misfiring during warm up, worsening emissions (Misfire CARB_B1)
Shadow-memory:
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
3F/14 - Control unit self-test 3
EWS -> 0F/3F - Power on reset
13/06 - Toleration of changing code increased, key 1
10/01 - Wrong identification, key 1
12/02 - Wrong changing code, key 1
03/01 - Toleration of changing code increased, key 0
11/01 - Wrong password, key 1
ABS -> 68/01 - Error steering angle Control unit
LEW -> 09/5D - No CAN message (ASC)
04/1F - 90 degrees difference of wiper too large (Adjustment operation)
10/7F - Watchdog
SRS -> 50/A0 - Power supply, undervoltage
Shadow-memory:
50/20 - Power supply, undervoltage
IKE -> 90/84 - Voltage supply, terminal 15, faulty
11/84 - Acoustic transmitter disconnected (gong tone 1/2/3)
BF/88 - Internal fault, EEPROM checksum, coding incorrect/incomplete
C7/81 - Tank sensor 1, left.........
po vymazani:
DME -> Shadow-memory:
ABS -> 61/FD - Steering angle adjustment necessary
SRS -> Shadow-memory:
MID -> 03/21 - No valid status response of TELEPHONE
LRA -> Shadow-memory:
00/00 - Terminal 30
Bohuzel dalsi den jsem jel nakupovat a motor se asi po 20 minutach roztrepal, zacal svitit Check Engine a mel jsem obavu ze nedojedu.Nechal jsem to stat asi 30 minut no a pak jsem teda vyrazil na zpatecni cestu- zrejme na par valcu s rozsvicenym Ch.Engine.
Napichl jsem to znova na Pa soft(BMW Scanner 1,4)
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> EE/B3 - Misfire, cylinder 1, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1)
EF/B3 - Misfire, cylinder 2, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1)
F0/B2 - Misfire, cylinder 3, misfiring during warm up, worsening emissions (Misfire CARB_B1)
Shadow-memory:
pak na Inpu
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 10/15/16 20:18:37 ECU: MS430DS0 JobStatus: OKAY Variant: MS430DS0 -------------------------------------------------------------
RESULT: 3 errors in error memory ! -------------------------------------------------------------
238 burning fail Cylinder 1
Error frequency : 4 Logistic counter: 40
TCO 77.25 Grad C N_32_TOL 1920.00 rpm MAF_TOL 413.98 mg/stk MAF_BOL 141.62 mg/stk aufgetreten vor (rel. BZ) 0.20 h
Misfire CARB_A Misfire CARB_B1 --- --- Error to relevant Error debounce Error currently not available sporadic Error
Errorcode: EE B3 04 28 A7 3C 4C 1A 6C 20 -------------------------------------------------------------
239 burning fail Cylinder 2
Error frequency : 3 Logistic counter: 40
Errorcode: EF B3 03 28 A7 3C 4C 1A 6C 20 -------------------------------------------------------------
240 burning fail Cylinder 3
Error frequency : 1 Logistic counter: 40
TCO 72.00 Grad C N_32_TOL 3264.00 rpm MAF_TOL 245.12 mg/stk MAF_BOL 147.07 mg/stk aufgetreten vor (rel. BZ) 0.20 h
--- Misfire CARB_B1 --- --- Error to relevant Error debounce Error currently not available sporadic Error
Errorcode: F0 B2 01 28 A0 66 2D 1B 6C 20 =============================================================
Co jsem zatim cetl:
New Spark Plugs- objednal jsem nove
Swapped Coil Packs- zkusim pri vymene svicek
Inspected for Vacuum Leaks- To by asi taky stalo za to
Replaced Fuel Injector O-Rings
Swapped Fuel Injectors
Good Compression
Bmw Disa Valve- objednal jsem tesneni
Snad i vymena separatoru atd atd.
Takze co je u techto motoru nejpravdepodobnejsi pricina tohoto pekla?
Moje stara kara 1998 523i s 52b25 motorem za 7 let takovy problem nemela....
add: Za studena to chybu nehlasilo takze problem bude asi po zahrati a roztazeni materialu....
no trosicku se to trepota i ochlazene rekneme 715-725rpm normalne to clovek asi nepozna ale stara M52 ma fakt hladsi beh.
No nejsou tam stejne zapalovaci civky- 5x Bosh, 1x Bremi- muze to delat nejakou neplechu?Udajne maji odlisny odpor ale jestli to vadi nevim.
Dnes jsem zkusil prohodit ty zapalovaci civky,vymenil tenkou podtlakovou hadicku (co jde na MAF) a trochu jsem to projel ale zatim nic.Chybu to nehlasi ale me se to stejne nezda
Zitra udelam svicky.....
rzich
Klubové ID: 2009
Re: E39 2002 525I Tour trosku se trepe
#2 Příspěvek od rzich »
zapalovaci civka vymenena
svicky vymeneny
palivovy filtr vymenen
vzduchovy filtr vymenen
tesneni na disa vymeneno
MAF vycisten
Diagnostika nekdy najde chyby nekdy ne ale porad se to trosicku trepe..
Check engine zatim nesviti
pixely na budiku opraveny-tim to asi nebude
uz toho moc nezbyva tlaky, vstriky, nejake vzduchove pumpy a tak....
Naposledy upravil(a) rzich dne pát 11.11.2016 17:57, celkem upraveno 1 x.
Joshuax
Klubové ID: 2833
#3 Příspěvek od Joshuax »
U tech svicek, menil jsi i ty stopky od civek ? Svicky stoji prd, takze to kazdej rad vymeni, ale ty stopky stoji nejakej ten krejcar a kazdej na to prdi a pak meni civku a divi se, ze to nepomohlo :) Chyby v diag nemusi rict vse, ale co live data ?
E36 328i Cabrio, E39 523i Tour, E61 530d, E66 745Li
ex E53 3.0i
rzich
Klubové ID: 2009
#4 Příspěvek od rzich »
Stopky jsem nemenil, mam za to ze pokud me vylozene plandaji na stare kare(bezi jak po masle) a tady vydavaji takovy cucavy,podtlakovy zvuk budou dobre.Zkusim tam nejaky kontact cistic. Live data- nevim presne na co se zamerit a nasledne to posoudit- toz tak
rzich
Klubové ID: 2009
#5 Příspěvek od rzich »
navic chod motoru se menil pri odpojeni a znovu zapojeni od civek.Mozna vacuum, spatny tlak na liste, zatim nevim...Proste bez nejake kloudne rady to bude drazsi.Ale zvykam si chlapci...
rzich
Klubové ID: 2009
#6 Příspěvek od rzich »
Motor procisteny BG 109, novy olej.
Nekde to pricucava asi vzduch.Smerem za disou byly gumove zaslepky jedna byla praskla ale bohuzel to asi ono nebylo. Test nic vic neukazal.Zpozdena reakce na plynovy pedal ale ta tam byla.
https://youtu.be/1rrIUX3n5oA
rzich
Klubové ID: 2009
#7 Příspěvek od rzich »
Aspon, ze bude Trump president!!!
Filozof
Klubové ID: 1044
#8 Příspěvek od Filozof »
někde jsem četl že zlobil motor a pomohl až repas jednotky ECU...prostě po těch letech už zlobí ...ale jistě na to přijdeš až vše vyměníš a uděláš generálku motoru :-)
rzich
Klubové ID: 2009
#9 Příspěvek od rzich »
Joo ja vim, ALE ME TO BAVIIII.Pokud nebude zitra chcat udelam termostat se sensorem teploty a remeny.Dneska to byl jenom Air mass.Lambdu mozna zvazim taktez.Uz se to blizi, mozna :lol:
Nahovno je ze me ruzne diagnostiky ukazuji rozdilne veci ohledne lambd ale jak rikam, me to BAVII.
