E39(530D)- DDE chyba(smooth running controller)
Napsal: stř 11.04.2018 20:23
Zdar,
vedel by nekdo neco ohledne chyby DDE – smooth running controller 0x0016013.
530D(142kW),rv 2000, 190k km
ISTA reportovala tuhle chybu DDE40KW0 0x001613: DDE:Smooth running controller
probehl doporuceny test s nasledujicim vysledkem:
Kompletne studeny start
Correction injection volume from smooth running regulator in mm^3/stroke/cylinder:
Cylinder 1: -1.0
Cylinder 5: 4.7
Cylinder 3: -0.5
Cylinder 6: -1.0
Cylinder 2: -2.7
Cylinder 4: -0.1
OK: -5.0 to 4.0
Critical: Rate < -5.0 or > 4.0
hodnoty na valci 5 jsou nad limitem,ale po chvilce zacnou klesat a do cca. 5 minut se dostanou na +-2 a po kompletnim zahrati se dostanou az na 1.2
Cylinder 1: -0.8
Cylinder 5: 1.2
Cylinder 3: -1.1
Cylinder 6: 1.3
Cylinder 2: -0.9
Cylinder 4: -0.3
OK: -5.0 to 4.0
Co si o tom myslite? Budu muset resit vstrik na 5tce?
Dik za nazory.
Cylinder 1: -1.0
Cylinder 5: 4.7
Cylinder 3: -0.5
Cylinder 6: -1.0
Cylinder 2: -2.7
Cylinder 4: -0.1
OK: -5.0 to 4.0
Cylinder 1: -0.8
Cylinder 5: 1.2
Cylinder 3: -1.1
Cylinder 6: 1.3
Cylinder 2: -0.9
Cylinder 4: -0.3
OK: -5.0 to 4.0
Dik za nazory.
