very individual coupe E36 :-)
Jawak
- Klubové ID: 125
DC
- Výkonná rada
- Klubové ID: 55
LOPOLO
- Čestný člen
- Klubové ID: 1
kosh
- Klubové ID: 238
LOPOLO
- Čestný člen
- Klubové ID: 1
kosh
- Klubové ID: 238
jogurt
- Klubové ID: 99
stealth
- Klubové ID: 4
jogurt
- Klubové ID: 99
M3maniac
- Čestný člen
- Klubové ID: 76
Misa
- Moderátor
- Klubové ID: 62
kosh
- Klubové ID: 238
Jawak
- Klubové ID: 125
patras
- Čestný člen
- Klubové ID: 7
Vena
- Klubové ID: 1809
Hanz
- Klubové ID: 6
jogurt
- Klubové ID: 99
sumachr
- Klubové ID: 52
sumachr
- Klubové ID: 52
lopolo konecne potunil
General Information
Produced in 2001 - 2002
Curb weight 1100 kg / 2425 lbs
Length 4612 mm / 181.6 inches
Width 1900 mm / 74.8in
Wheelbase 2731 mm / 107.5 in
Layout Front, longitudinally mounted Longitudinal / RWD
Drivetrain
Engine 4.0 Liter V8 naturally aspirated engine with 90 degree
Displacement 3.997 liter / 243.9 cu in
Valvetrain 4 valves/cylinder, DOHC
Fuel feed Fuel Injection
Aspiration Naturally/Aspirated
Gearbox Pulled triple disc carbon fiber clutch; straight cogged six-
speed manual transmission with oil/air cooling at rear;
single section aluminum steering shaft, step-up
differential with viscous differential and mechanical
spreader differential and multi-plate differential; steel
drive shafts with tripod links
Performance
Horsepower app. 470 bhp @ 7800 rpm
BHP/Liter 100.1
Torque 470 Nm @ 6.500 rm
Redline 8500 rpm
Power to weight ratio 0.36 BHP/kg
jogurt
- Klubové ID: 99
